Blend door location
I have a 2001 stratus SE, the heater only blows hot air no matter the knob in what position it is. I think it is the blend door actuator, i cannot locate where it is. Someone that has a diagram of the location of the blend actuator? passenger or driver side? or is there another possible solution to my problem? i have a 2001 Stratus SE 2.4 l, suddenly the temperature control knob didnt work and stayed in hot. I was told that it could be the door blend actuator, how ever i cant find where it is located. Does someone has a diagram o the heater core??? i need to remove the door vent actuator. Please help me I have a 2001 Stratus SE 2.4 l, suddenly the temperature control knob didnt work and stayed in hot.I was told that it could be the door blend actuator, however i cant find where it is located. Does someone has a diagram of the heater??? i need to remove the door blend actuator. Please help me |
Merged your duplicate threads. Please only post once regarding the same issue. There are videos on YouTube if you search. |
