replaced head set timming belt and
Old 08-03-2006, 01:43 PM
tacoboy's Avatar
tacoboy
tacoboy is offline
Default RE: replaced head set timming belt and
Don't forget to properly torque your idler/tensioner as well. This is critical and will put the right amount of tension on the timing belt and keep both marks (crank and cam) lined up with each revolution. Crank by hand twice to confirm they line up exactly every time.
Old 09-04-2006, 03:51 PM
kube1989's Avatar
kube1989
kube1989 is offline
How long does it take to "relearn"?
I replaced my timing belt, marks lined up perfect (as perfect as the belt teeth would allow, which was about 1/3 tooth) and it lopes at idle and stopped at lights- runs fine at 1100 rpm +.
Mine is in a 2000 Cirrus.... do I need the DRBIII thing to reset it? Whatever that is?
Please help.
Quick Reply: replaced head set timming belt and
