Magnum SRT-8 That thing got a Hemi? Indeed, a 6.1L Hemi that is. The Dodge Magnum SRT-8 is the most extreme factory wagon.
06 magnum dashlights
Old 05-20-2010, 03:35 AM
john hink's Avatar
john hink
john hink is offline
Talking 06 magnum dashlights
my 06 magnum dashlihgts wentout and i am currently using a flashlight.i have checked the cluster and went as far as trying a used cluster too see if that was the problem.unplugged all wiringharnesses under hood and checked pins,plugs for corrosion.no problem there.dimmer switch is fine as everything but the lumination works.has anyone had this problem or know a solution?HELP PLEASE AS FLASHLIGHT BATTERIES ARE GETTING EXPENSIVE LOL
Old 05-26-2010, 02:04 PM
Ramdit's Avatar
Ramdit
Ramdit is offline
Have you checked the fuses in the PDC next to the battery in the back?
Old 05-27-2010, 12:53 AM
john hink's Avatar
john hink
no but was told there is no fuse for just the dashlights.is it possible its a relay that is malfunctioning?
Old 05-27-2010, 12:32 PM
Ramdit's Avatar
Ramdit
Ramdit is offline
Is just the cluster out or is it the whole dash (heater controlls, power switch buttons etc) out also?
Old 05-27-2010, 07:37 PM
john hink's Avatar
john hink
yes just the clusterlights.everything works just no dashlights.i even tried a used cluster to make sure my cluster wasnt the problem.
Old 06-02-2010, 01:24 PM
Ramdit's Avatar
Ramdit
Ramdit is offline
From what I've found out, there are two ways the instrument panel lights work. They either use the steering controll module or the cluster to supply power for the lights. At the cluster in connector 3(white) on pin 11 (or/gy wire) there should be power when the lights are turned on. I am assuming since you already tried another cluster and the lights worked the same way they do now, that the steering module has the driver for the lights. That same color wire should go to all the components that light when the head lamp switch is turned on. You should check for voltage there, and could try jumping that circuit if there isn't any.
Old 09-15-2018, 05:45 PM
Distractor_Beam's Avatar
Distractor_Beam
Distractor_Beam is offline
Default electroluminescent backlight repair
There's a video on youtube:
Repairing an Instrument Cluster Backlight with the ELD-M on a 2005 Dodge Magnum
This also works on the Charger, Sebring, 300C, and Challenger.
Quick Reply: 06 magnum dashlights
