I know all of the 5.2 and 5.9 magnums will bolt in. Biggest problem is you need to eliminate the mech. fan. and install electric fans in front of the radiator. BTW that is the way Shelby did with the Shelby Dakota's.
But the magnum exhaust manifolds work, and you can use the stock 5.2 92-96 dakota exhaust.
