Innovate Wideband Help!!!
Old 06-28-2007, 07:56 PM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
Default RE: Innovate Wideband Help!!!
14.3-14.7 at idle or at wot?
Old 06-28-2007, 08:06 PM
Aceburner's Avatar
Aceburner
Aceburner is offline
Idle, that what the gauge reads. Is that bad or do I need to calibrate it again?
Old 06-29-2007, 03:32 AM
PSI Chick's Avatar
PSI Chick
no that's what it should read. it should always read that, regardless of what stage you put in. the 10 a/f's that s2 gives out is at wot.
Old 06-29-2007, 08:40 PM
Aceburner's Avatar
Aceburner
Scratch my last post, I took the car out for a spin and punched the gas. The richest reading I got was 10.7 and then it idles down back to 14.7 or whatever. That's sounds about right? It goes way lean when you let off the gas all the way to the point where the gauge read o2 but then levels out again.
Old 06-29-2007, 10:27 PM
PSI Chick's Avatar
PSI Chick
that's about right
Quick Reply: Innovate Wideband Help!!!
