Srt hit the 50,000 mile mark....
Old 06-28-2008, 12:31 AM
Kapitald's Avatar
Kapitald
Kapitald is offline
Default Srt hit the 50,000 mile mark....
So whats up with maintainence? Should I do anything special/different?? I just changed out the plugs not too long ago so those should be fine, my wires are crane cam wires...i think im gonna get some granatellis in not too long just for the heck of it....i changed the pcv valve on the car about 4-5 months ago....
the oil is kept up as it should be....and the transmission fluid leaks really slow so i put fresh fluid in it every oil change about..maybe a lil sooner sumtimes....think it still needs a change even though it leaks?? I havent changed it since i got it due to the leak...
and both front wheel bearings went bad on me and the whole hubs were replaced....even the spindle on one side...(just how i got it from the junkyard)
i hate the ride on my car so ruff...i have the goldzone lowering springs on it...(came on the car)...i wonder if they have taken a toll on my struts/shocks....
Old 06-28-2008, 01:24 PM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
Default RE: Srt hit the 50,000 mile mark....
you should think about doing the timing belt around 60k
Old 06-29-2008, 01:12 AM
Kapitald's Avatar
Kapitald
Kapitald is offline
really?? wasnt expecting that one lol
ill keep that in mind...
Old 06-29-2008, 01:55 AM
Pressurecooker's Avatar
Pressurecooker
Pressurecooker is offline
Yeah the t-belt is a good idea.
I would (and do) change the tranny fluid once a year.
My car is just over 40k now and I will be changing a very worn (!?!?) left outer tie rod tomorrow.
The new one I got from Murrays is a TRW and has a grease zirc and lifetime warranty. It was ~27.00 This will be the first big maintenance thing I've had todo to this car and I run it hard. I will do the right one soon just because.
I just did the front brakes for the first time about a month ago.
I Know the clutch is nearly done after that last trip to the dragstrip about 2 months ago as it has not felt the same since. It is still not slipping at this time (knock on wood).
Old 06-29-2008, 12:03 PM
flamingpinhead's Avatar
flamingpinhead
flamingpinhead is offline
Section Moderator
Dodge Forum Moderator
yeah, should be changing out the tranny fluid bout every 12-15k (ok, maybe im paranoid but i do)
just changed my pcv at 36k mark. think a coolant flush is in order at this point?
Old 06-29-2008, 12:38 PM
PSI Chick's Avatar
PSI Chick
nah the coolant is usually fine, but it wouldn't hurt. not a must do, but not a bad idea. ps - when you do the timing belt, change your water pump and tensioner at the same time.
Old 06-29-2008, 07:57 PM
lblackneon's Avatar
lblackneon
lblackneon is offline
ORIGINAL: PSI Chick
I hate that part.
I'm at 51k and I'm debating on putting some different cams in while I'm changing the timing belt. Might as well.
Old 06-30-2008, 12:56 AM
flamingpinhead
Section Moderator
i hear you on doing both. my minivan - tensioner got replaced after it died and would barely hold a belt on, only to find out the water pump was shot[:@]
Old 06-30-2008, 01:47 PM
lblackneon's Avatar
lblackneon
Preventive maintenance. I did the same thing when I changed my timing belt on my 00 Neon along with the cam job.
Old 07-01-2008, 01:05 AM
Kapitald's Avatar
Kapitald
Kapitald is offline
wow...so timing belt, water pump, and tensioner...all at the same time...ouch im lookn at what...200 bucks??? ouch ouch ouch...
i think mine could use a coolant flush at 50...its startn to look a lil brown and durrty...
Quick Reply: Srt hit the 50,000 mile mark....
