Upgrading to the SRT4
02-04 srt-4? i want an 02 srt-4 just so i have the only one in exsistance. and if i have an 05 does that mean these axles wont work for me? i dont know how much i trust a site that cant figure out what years a car was made. just my 2 cents o and love how they have a set for the automatic tranny neon srt-4s LOL classic
well, that shop is EXTREMELY reputable for thier axles, so if you dont want to buy because of an 02 typo....um ok?
Also, you are aware that auto trannys are now in existance for the SRT right? Not by factory of course.
In fact, take a look at the auto tranny description. Says they are for Darrell *** automatics.
You are beating a dead horse doing a swap into a standard neon. Has it been done? Yes, I have seen two. One of which you cant even tell. Would I do it? Not a chance. The TIME alone is going to kill ya let alone the $ ammount. The ammount of headaches I have seen is enough to discourage me.
Do you self a favor and pick up a used one in good shape and work from there. It will cost less $ and headaches in the long run...
If not, I know of a car that has had the swap already done, and is for sale. But it will cost you the same for a used "true" SRT-4
well if they are that reputable then they really need to check their facts. im not saying they are a bad company ive never used them and honesly in dont know anything about them. all i know is its not that hard to get the facts right and personally i think it looks bad to put up incorrect info on your own website. just my opinion
Do a bit of research i would assume. If you own a SRT-4, but never heard of a DCR automatic, then I would think you been in hiding for a bit...
Unreputable due to a Typo?
Suspension probably does. Intake manifold and ECU will not. The computer is specifically specd for the boost application of the SRT motor.
Add: you will need the intake manifold because that has the MAP sensor provision that the ECU needs to see. (among many other boost/fuel related sensors)
^ not to mention the flow difference. the runners on the srt are designed alot different than the sxt. if it even bolted up to the block cause it probly will it wont flow near as well and like 70x7 said the sensors for the ecu are not there. if you already have the engine and tranny the intake is the cheapest part. i would make sure the engine you got didnt already come with an ecu cause i would think it did. just my 2 cents
