WHERE'S IS DA O2 SENSOR LOCATED?
HEY!
i just finised installin my Apexi TT. I can't use the auto timer cause the instruction did not show where the wire was located. Need some help! Thanx Roach [:@] |
RE: WHERE'S IS DA O2 SENSOR LOCATED?
you have to be more specific on your question.y are you lookin for the o2 sensor for installing your TT
Which 02 sensor? Upstream or downstream?
It's on the down pipe right behind the clamp for the cat, were it hooks up to the rest of the exhaust system on the right side. And its a bugger to get to!
The O2 sensor on in the ECU is what i'm lookin for. which i havent found it yet... the ECU.
Roach |
| All times are GMT -4. The time now is 05:32 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
