Dynoed 300whp/332tq
Dynoed 300whp/332tq
stock turbo w/ upgraded compressor wheel...complete fuel system w/ return line...the fpr was messed up but is fixed now...redynoing again this weekend...hoping for 325whp/350tq
mods:
cca fmic
bdj 3" dump
s0 pcm s2 injectors
safc2
aeromotive fpr w/ return line
walboro 255 fuel pump
agp wga
k&n sri
plus some other odds and ends
a/f's were tuned between 11.2-11.5 max
this proves that the upgraded wheel works as i hit peak hp right at redline and my peak tq was at like 3200 rpms, but stayed above 300 all the way to like 5000rpms then only fell to 285 at redline
mods:
cca fmic
bdj 3" dump
s0 pcm s2 injectors
safc2
agp wga
k&n sri
RE: Dynoed 300whp/332tq
Very Nice. I never hit 300whp on the stock turbo... I didn't realize at the time but the MSD programmable was pulling timing on me because of a default base map. Didn't discover that until I got the big turbo in.
You need to add water injection... bet you could hit close to 350 with that.
Ok, once again for us slow people. ( I know I'm not the only one)
I'm having trouble with the alphabet soup.
I can figure most of it out most of the time but I have a few questions.
1) whats cca fmic ?
2) safc (2?)
3) bdj ?
I'll admit ignorance, but stupid people don't ask questions.
Also, to install an upgraded compressor wheel, does the housing need to be machined to match? Can you do it yourself?
If its reliable as you say, great going!
1) whats cca fmic ?
2) safc (2?)
3) bdj ?
Trending Topics
upgraded cca front mount intercooler
s-afc2 is somethjing that controls the bigger injcetors...
bdj is just a company that makes srt-4 turbo back exhausts
Hope that helps a bit!
in theory you COULD do the turbo thing but it would be a good idea to let some1 that is experienced with turbos do it for you
Yeah thanks. I'm just a displaced aircraft mech making a living (for the moment) as a diesel truck mechanic. I'm good with all sorts of shortcut jargon. I am however, new to the world of high perf automotive turbos and supporting mods as this is my first one. So I'm trying to play catch up. I've always been more of a big block 440 4 barrel guy. Ya smell what I'm steppin in? I aint skeered of no turbo though, we use 'em on airplanes and trucks both, all the time. There aint nothin to 'em really. The question I have about the turbo is; is there machining that has to be done to the housing when you change the turbine wheel? That part I could not do. Well, maybe not, I do have access to a simple machine shop.
lil dictionary of turbo-jargon abbreviations:
FMIC: Front Mount Intercooler
BOV: Blow Off Valve
MBC/EBC: Manual/Electronic Boost Controller
CAI: Cold Air Intake
SRI: Short Ram Intake
WGA: Wastegate Actuator
SAFC: Something Automatic Fuel Control????? dont know what it stands for
STS: Short Throw Shifter
DP: Downpipe
MPSC: Mopar Supercenter :-)
CF: Carbon Fiber
my brain hurts. thats all.
BOV: Blow Off Valve
DP: Downpipe
CF: Carbon Fiber
