Commonly Used Automotive Abbreviations
There are more coming, this is just a start. Feel free to recomend new ones that I may forget.
ABS - Anti-Lock Brakes ABRS - Air Bag Restraint System AIS - Air Injection System Alt. - Alternator A/T - Automatic Transmission ATC - Automatic Temperature Control ATF - Automatic Transmission Fluid AWD - All Wheel Drive AXOD - Automatic Transaxle Overdrive B+ - Battery Positive Voltage BCM - Body Control Module BHP - Brake Horsepower CAT - Catalytic Converter CB - Citezens Band CKP - Crankshaft Position CMP - Camshaft Position CTS - Coolant Temperature Sensor DEFI - Digital Electronic Fuel Injection DFI - Digital Fuel Injection DIC - Driver Information Center DIS - Distributorless Ignition System DLC - Data Link Connector ECT - Engine Coolant Temperature EFI - Electronic Fuel Injection EGT - Exhaust Gas Temperature EI - Electronic Ignition EVIC- Electronic Vehicle Information Center FI - Fuel Injection FLS - Fluid Level Sensor FWD - Front-Wheel Drive GDI - Gasoline Direct Injection GPM - Grams Per Mile GVWR - Gross Vehicle Weight Rating HC - Hydrocarbons hp - Horsepower Hz - Hertz(Cycles Per Second) IFI - Indirect Fuel Injection IAT - Intake Air Temp KM/H - Kilometers Per Hour kV - Kilovolt MAF -Mass Air Flow MAP - Manifold Absolute Pressure MAT - Manifold Air Temp mA - Milliamps MFI - Multiport Fuel Injection MIL - Malfunction Indicator Light MPI - Multi-Point (Fuel) Injection MPV - Multi-Purpose Vehicle mV - Millivolts NOX - Oxides of Nitrogen O2S - Oxygen Sensor OBD - On-board Diagnostics OD - Overdrive OE - Original Equipment OEM - Original Equipment Manufacturer OS - Oxygen Sensor P/B - Power Bakes P/N - Part Number PCM - Powertrain Control Module PGM-FI - Programmed Fuel Injection PNP - Park Neutral Position Switch P/N - Park/Neutral PPM - Parts Per Million PRNDL - Park Reverse Neutral Drive Low P/S - Power Steering PSI - Pounds Per Square Inch PTC - Pending Trouble Code R/A - Resume or Accelerate RABS - Rear Anti-lock Brake System RCC - Rear Climate Control RECAL - Recalibration RECIRC - Recirculation RF - Radio Frequency RFI - Radio Frequency Interference RFWS - Right Front Wheel Speed RKE - Remote Keyless Entry Rly - Relay RM - Relay Module RPM - Revolutions Per Minute RPO - Regular Production Option RSC - Roll Stability Control R/T - Road/Track RVAC - Rear Video/Audio/HVAC Module RWAL - Rear Wheel Anti-lock RWD - Rear Wheel Drive SC - Supercharged SEFI - Sequential Electronic Fuel Injection SES - Service Engine Soon SFI - Sequential Fuel Injection SIL - Shift Indicator Light SIR - Supplemental Inflatable Restraint SIPS - Side Impact Protection System SPFI - Sequential Port Fuel Injection SRI - Service Reminder Indicator SRS - Secondary Restraint System Sw. - Switch SWB - Short Wheel-Base TACH - Tachometer TB - Throttle Body TC- Turbocharged TD - Turbo Diesel TDI - Turbo Direct Injection TPI - Tuned Port Injection V - Valve Vac. - Vacuum VIN - Vehicle Identification Number VOM - Volt-Ohmmeter VSS - Vehicle Speed Sensor Of course if you cant find it here, you can always click here fro one site, or here for the google search. I'll update this as much as I can, but I am only one person, going to college, and working full time. I'll do my best. 9/15/09 Edit Transmission codes/types can be found on this site I tryed to post the chart, and it turned out to be mumbo jumbo. I'd love to figure out a way to do it, but until then you can just click on the link, and you'll see the chart. 10/18/09 Edit MIL-Malfuntion Indicator Lamp CEL-Check Engine Light SES-Service Engine Soon Light DTC-Diagnostic Trouble Code DLC-Data Link Connector(OBD2 Connector) OBD-On-Board Diagnostics There first three, MIL,CEL, and SES, are used interchangably, but they all refer to the same indicator on the dash, in some vehicles, a service engine soon, or the words check engine, or in some vehicles just a yellow illuminated engine. But of course they all mean the same thing, a DTC(diagnostic trouble code) has been set by the pcm, due to a malfuntionin the system. A code reader is needed to read, and erase the codes, which will turn off the light. You can usually go to AutoZone, or Advance and theyll check and clear it for FREE. |
Thanks 004x41500. Good work, I sticky-ed it!
thanks. hopefully itll help the new guys out here. i got lucky, and came from a family of GM workers. (dont ask how i became a dodge man, lol)
thanks for the in fo.. but i was under the assumtion BHP was Base Horse Power... but we all know what ones does when they assume....
Brake horse power is similiar to rear wheel horsepower. You engine may have 300 HP but only 250 RWHP,
FF |
Companies nowdays use SAE HP ratings for the most part......yeah right, my SRT-4 was rated at way below it's actual output.......for insurance reasons, I was told.
Dusty |
The cars in the early seventies were exploited this way, too. They undestimated the horsepower,
FF |
Originally Posted by DalesSmith2025
(Post 2009649)
though you may have a 390hp engine, the rearwheels might only put out 300 due to the driveline, ujoints and such. however the engine may only make 200ft lbs of torque, but because the torque convertor typically multiplies the engines torque, your rear wheel torque could be 225 or even 250ft lbs. hope this helps |
