rough idle?
i have a 1994 ram 1500 with a 3.9. today i changed the plenum gasket. after i got everything back together it was idling rough. i unplugged the two vacuum lines on the passenger side of the intake manifold next to the pcv port. it seems to run better with the vacuum lines unhooked . what could cause this? map sensor?
Welcome to DF! I see you already found the second gen section. :D
Welcome to DF. Post your questions in the 2nd gen Ram section.
1998 Dodge ram 1500 4X4 2500 front springs Hugh,s intake mod & plate double roller timg chain Accel Coil & yes $48.00 for adapter Snow plow truck automatic yuk! Megasquirt 3 .1 I built over winter took all my problems run,s very strong know.
Originally Posted by Beebeenation
(Post 3242034)
