biggest mud tire for st0ck suspension?? - DodgeForum.com
Go Back  DodgeForum.com > The DF Lounge > Off Topic
Reload this Page >
Off Topic A place to boldly go off topic. Just about anything goes.
Old 10-05-2004, 08:00 PM
tanker
tanker is offline
Default biggest mud tire for st0ck suspension??
im h0ping 35inch will w0rk, if not then i guess i have to settle for 33inch, im shur they will work. does anyon know?
thank in advance!
Old 10-05-2004, 08:04 PM
robust57
robust57 is offline
Default RE: biggest mud tire for st0ck suspension??
What kind of ride are you talking about? I have a 98 Durango and I am squeezing in 32 inch BFGoodrich M/T's. I have some rubbing going on.
Old 10-05-2004, 08:08 PM
tanker
tanker is offline
04 quad cab dakota 4.7l v8 4x4
Old 10-06-2004, 11:42 PM
Racer Rob
Racer Rob is offline
no way 35's are fitting with no lift.
Old 10-07-2004, 12:22 AM
tanker
tanker is offline
so what about 33's?
Old 10-07-2004, 04:07 AM
Ragabash
Ragabash is offline
35s rub bad
33s rub on the back section of the plastic wheel well but only when you are in a tight turn or flexing over rocks. I used a sawz-all on the front half of the plastic and the that elimintaed the problem.
Also 15 inch steel rims will fit, aluminum will not without shaving the calipers 1/4 inch.
I am currenty running Extreme Alloy 15 X 10 rims with 33" Pro-comp Mud terrains. Outstanding offroad tire in all except snow of course. I Also have a set of TSL 34.5 X 10 swampers stuffed onto a set of 15X8 steel wheels. They are like cookie cutters and are good for "Cholctale Milk" Mud racing.
Old 12-14-2004, 07:19 PM
Ram 2002
Ram 2002 is offline
What size of tire will fix into a 2002 Ram 1500 Quad cab without any modifications?
Old 12-22-2004, 03:55 AM
hemi77
hemi77 is offline
I just put a 33x12.5x17 on my 2004 1500 Ram Hemi. All I did was tighten up the torsion bars to give a little more clearance. And I'm running the stock 17 inch rim. No rubbing, unless your blasting in a parking lot about 50 miles an hour. Also tightening up my torsion bars didn't change the ride at all. Brought the front up about 1.5". But 35's forget about it. Unless you have about a 4" inch lift.
Old 01-16-2005, 03:30 PM
55DodgeFan
55DodgeFan is offline
I have 33" tire on my 01 Quad and it rubs when the wheel is turned hard to the left.
Old 01-28-2005, 05:24 PM
RJlovesbeer
RJlovesbeer is offline
How well do the 33"s perform offroad on ur 01? What rim are you running? My stocker 31s are lookin like racing slicks....
Quick Reply: biggest mud tire for st0ck suspension??
Featured Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
