Go Back  DodgeForum.com > The DF Lounge > Off Topic
Reload this Page >
My Tires HATE Me...
Off Topic A place to boldly go off topic. Just about anything goes.
My Tires HATE Me...
  #21
Old 10-16-2009, 03:27 PM
BadStratRT's Avatar
BadStratRT
BadStratRT is offline
The Forum Tyrant
Dodge Forum Administrator
Originally Posted by Horseapples View Post
Junior, you need a bigger shooter in the carb. The bog is from a lean condition when the butterflys open and not enough fuel is mixed with the hi volume of air. The number of the discharge nozzle is stamped on the front. Stock size is probubly a .25 (measured in thousandths). I would suggest a .31 to .35
http://www.summitracing.com/search/?...harge%20&dds=1
i was going to ask what type of secondaries he is running...im assuming vacuum? is that a double pump carb? i agree that its more likely a tuning issue than something that requires taking the carb off and dealing with downtime.
jr, i daily drove the mirada for 3 years, until i went to college...i feel your pain.
  #22
Old 10-16-2009, 03:32 PM
Jr. Mechanic
Jr. Mechanic is offline
See, I had figured it was a lean condition considering if I half choke it, the hesitation disappears. However, it was something that developed later. Right out of the box the carb performed beautifully, only adjustment I had to make was the idle.
  #23
Old 10-16-2009, 04:29 PM
Horseapples's Avatar
Horseapples
Horseapples is offline
the lean condition could be brought on by many things, such as a different cam, vaccuun leak, timing change or addition of power brakes or other vaccuum operated accessorie. Swapping a discharge nozzle is pretty cheap and quite easy to do. they are right inside the primary air horn, held in with a large phillips head machine screw. DO NOT operate the throttle with the discharge nozzle(S) removed or it will spit out the check valve, then you are screwed! If it is a double pumper, change both nozzles, probubly 28 or30's would do nicely, if vaccuum secondary, all you have is the primary nozzle, and i would go with the 31 to 35 range.
  #24
Old 10-16-2009, 04:39 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
what about slow secondaries?
  #25
Old 10-16-2009, 04:47 PM
Horseapples
A secondary spring that is too light, or too fast, could cause a bog, but too slow would just make it slugish. Junior needs a trick kit to tune it correctly. The trick kit comes with discharge nozzles and secondary springs. As well as accellerator pump cams, hi-flow needle and seats and gaskets. but they are a little pricey.
http://www.summitracing.com/parts/HLY-37-933/
  #26
Old 10-16-2009, 04:54 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
discharge nozzles...my dad always calls them "carb pissers"...
do those kits come with jets?
  #27
Old 10-16-2009, 05:26 PM
Horseapples
No, but they come with everythingelseto super tune a Holley. here is a jet kit.
http://www.summitracing.com/parts/AED-6000/
  #28
Old 10-16-2009, 05:37 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
thats the one that i have...except weve had it for a decade, and its packed full of jets...
  #29
Old 10-16-2009, 11:46 PM
Jr. Mechanic
I'll probably end up buying a trick kit this spring when pull the engine back out. I've just been living with the hesitation, once the motor catches you can't tell anything is wrong. The secondaries are opening beautifully, btw.
Quick Reply: My Tires HATE Me...
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
