Off Topic A place to boldly go off topic. Just about anything goes.
Idling high...
Old 12-15-2009, 02:15 PM
Midnight SRT's Avatar
Midnight SRT
Midnight SRT is offline
Nightly Creeper
Dodge Forum Administrator
Default Idling high...
So, my Stratus is idling (steady) at 2,000 RPM's in park and neutral. Then about 1,100 RPM's in drive and reverse. It's not the idle air control motor... My mechanic is on vacation and his employees can't figure it out. Ideas?
3.0 V6 Mitsu engine
Had a check engine light. He put a new IAC in and the check engine light went off but it's still idling high.
Old 12-15-2009, 02:35 PM
Laramie1997's Avatar
Laramie1997
Laramie1997 is offline
I'm not real familiar with that V6, but do you have a rubber line headed into the TB controlling idle? Mine rotted off and was sucking in more air than it needed and the PCM picked it up as more throttle. Replaced that little section of line and reset the PCM and it was fixed.....
So I say Vacuum line leak somewhere.
Old 12-15-2009, 02:48 PM
Frenchy
Frenchy is offline
guessing vac leak, as well.
When I remove the vacuum line from my throttle body on the celica to run some seafoam in it, it picks up about 500rpms to keep from stalling.
Old 12-15-2009, 04:56 PM
Exubus
Exubus is offline
I was guessing vacuum leak too. Maybe a TPS, but I doubt it.
Old 12-17-2009, 01:34 PM
Midnight SRT
Nightly Creeper
No vac leak.
Guess I'm taking it to the stealership.
Computer?
Quick Reply: Idling high...
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
