Big question - DodgeForum.com
Go Back  DodgeForum.com > The DF Lounge > Off Topic
Reload this Page >
Big question
Off Topic A place to boldly go off topic. Just about anything goes.
Big question
Old 05-15-2006, 03:30 AM
Challenger Lover
Challenger Lover is offline
Default Big question
I feel bad asking this because im a fan of car/ truck but I just dot know what does a 3.73 transmission mean or a 4.47 or ... well the number come from what
Old 05-15-2006, 03:38 AM
DodgeRam318_4bbl
DodgeRam318_4bbl is offline
Default RE: Big question
That's the ratio of the drive gear. For example, my Dad's Capri had 4.10's in the rear end. That means that the gear in the diff. had a ratio of 4.10 teeth on the rear end gear to one tooth on the axle gear. The higher the ratio, the more pulling power it has, but the top speed is lower. That's why transmissions have higher ratios in the low gears and lower ratios in the high gears.
Old 05-15-2006, 03:39 AM
BadStratRT's Avatar
BadStratRT
BadStratRT is offline
The Forum Tyrant
Dodge Forum Administrator
Mat, do you mean the differential gearing? transmission gearing and differential gearing are different.
Old 05-15-2006, 03:45 AM
Challenger Lover
well when it syas rear axle ratio at 3.73 [>:]
Old 05-15-2006, 03:46 AM
DodgeRam318_4bbl
See what I said above.
Challenger Lover
oh yeah nice so a 3.73 give high speed but low on accel ?
Old 05-15-2006, 03:47 AM
DodgeRam318_4bbl
Other way around. The higher the ratio, the faster it will be off the line.
Old 05-15-2006, 03:49 AM
Challenger Lover
for a 0-60 you better had a '3.73' or something like 4.10 ...
Old 05-15-2006, 03:58 AM
DodgeRam318_4bbl
It depends on what you want. If you want something like a daily driver or a circle-track racer, then something in the mid-range like 3.51's or even 3.73's would be good. But if you're drag racing, then something like 4.10's or 4.54's would be better.
Quick Reply: Big question
Featured Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
