freddyboy |
12-03-2012 01:47 PM |
My first Mopar...A 1984 Ramcharger!!!! Scary engine noise!!!
Hey everybody.... I was finally sick and tired of my 1998 GMC 4x4 breaking so I got a 1984 Ramcharger with a 318. For a second or two at cold start the engine has a rod or main bearing knock. After 2 seconds it goes away and doesn't come back until the truck sits over-nite. It idles smooth, doesn't smoke and has great throttle response. The truck supposedly has 126k miles and I was told that the motor only has 20k on it. It has been cosmetically restored and came with a plow so I didn't worry about the brief engine start-up noise. Are these engines known for start-up noise? I know they have steel cranks in them. If I do wind up changing the motor out is a swap to a 360 a better idea? Is a 360 a bolt in swap? This truck will see maybe 3k miles a year of use. The only plowing it will do is my driveway. I plan to keep it for many years and treat it right. Thanks in advance for any advice!
