Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Which sensor is which?!?!
Old 05-08-2019, 11:27 PM
Jerrydtm's Avatar
Jerrydtm
Jerrydtm is offline
Default Which sensor is which?!?!
Finally getting to rebuilding my 93 dodge stealth sohc. I ordered a tempature sensor knowing I should probably replace since when I flushed the radiator it looked like mud. And I have the part but there are a couple spots it looks like it would go. I have looked all through the manuals posted on 3sx but couldnt pinpoint which sensor to change. Is it the one on the thermostat housing top part? Or the lower portion attached to the intake plenum??
Old 05-09-2019, 08:30 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
If you have more than one sensor, likely one is for the gauge in the dash, which will be a one wire sensor, and the other will be for the PCM, which should be a two wire sensor.
Old 05-09-2019, 08:42 AM
Jerrydtm's Avatar
Jerrydtm
Jerrydtm is offline
Oh okay that would make sense appreciate it!
Quick Reply: Which sensor is which?!?!
