Vacuum leak
Old Nov 21, 2016 | 10:56 AM
G SKI's Avatar
G SKI
Default Vacuum leak
Cant find a vacuum leak. Do you have a picture of all the vacuum lines 05 sxt auto? Maybe I missed one. Where does that small plastic tube go into the fire wall off the brake booster? That tube has tape on a spot, maybe it was broken and they put tape to cover it.
Old Nov 21, 2016 | 01:00 PM
Sonocativo's Avatar
Sonocativo
Check it, then buy a piece of rubber tubing/hose that fits snuggly and splice it if it is cracked.
Old Nov 21, 2016 | 01:01 PM
Sonocativo's Avatar
Sonocativo
You can spray carb cleaner on connections and listen if idle jumps up, easy way to find leaks old school.
Old Nov 21, 2016 | 03:26 PM
darthroush's Avatar
darthroush
Section Moderator
Old Nov 24, 2016 | 09:36 AM
paw paw's Avatar
paw paw
Come by a Swisher Sweets cigar, "T" into & blow some smoke into the vacuum system close to where you think the vacuum leak may be & look, or smell for smoke at the leak spot.
Old Nov 24, 2016 | 12:19 PM
G SKI's Avatar
G SKI
Thanks for the picture and ideas, Ill see what i can find after Thanksgiving. Thank you.
