Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Turn Signals, Hazards, Brake Lights not working
Old 04-26-2009, 11:28 PM
tigerhornet's Avatar
tigerhornet
tigerhornet is offline
Default Turn Signals, Hazards, Brake Lights not working
My headlights work fine, but the turn signals, hazard lights, and brake lights don't work. when i hit either the hazard light switch or the turn signal switch, absolutely nothing happens, no click, no indicator lights.
Old 04-26-2009, 11:46 PM
BlueBeast2's Avatar
BlueBeast2
BlueBeast2 is offline
My guess would be the multi-function switch
Old 04-26-2009, 11:48 PM
xray99's Avatar
xray99
xray99 is offline
Sounds like you got a wiring gremlin, try changing the flasher fuses yet ?
Old 07-28-2010, 11:45 AM
n_greenscapes's Avatar
n_greenscapes
n_greenscapes is offline
tigerhornet, did you ever figure out what was wrong with your truck? I have a '97 2500 and the same thing is happening to me. I replaced the multi-function switch and stop lamp switch and nothing happened.
Old 07-28-2010, 11:55 AM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
parklight fuse?
Old 07-28-2010, 04:28 PM
2k10HemiRam's Avatar
2k10HemiRam
2k10HemiRam is offline
I still have a fun issue with my right blinkers, everything works just flashes super fast which sounds annoying, but try replacing the flasher/hazard light replay. The relays changed over the generation but I thing pre-99 the flasher/hazard light relays were two separate round silver relays in the cab relay box. Think it was 99 then combined the two into a single blue square relay. It's only 32 bucks at autozone, gonna pick me one up this weekend after i get paid and see if that fixes that problem.
Old 10-21-2010, 09:48 PM
dazza5757's Avatar
dazza5757
dazza5757 is offline
Hi I know what your problem is, had the exact same problem, fix is easy your problem is the connection where the light bulb plugs into holder. Take bulbs out and clean plug contacts with a fine flat file, then make sure bulbs are pushed back correctly.
And you problem should be solved. I did this to all 4 front indicator bulbs and been fine since. Darren
Old 05-12-2011, 12:58 PM
hombre's Avatar
hombre
hombre is offline
I have same problem. Cleaned contacts no success
Old 05-12-2011, 01:03 PM
do ANY of the rear lights work?
Old 12-10-2011, 09:38 AM
SoGone12's Avatar
SoGone12
SoGone12 is offline
Default Any luck guys!?
Is there any update on this problem? I'm having the SAME problem on my 98 Dakota V6. My head lights and tail lights work but NO reverse lights, turns signals on either side/either end, and NO brake lights. I've tried checking fuses, changing the brake light switch under the brake petal, changing the multifunction switch on the steering column and checking the bulbs. I GUESS i'll go through it and check the connections today but it was just weird how they went out one by one. First no Turn signals in front, then in back, then no brake lights (only the third light at the top of the cab), then THAT went out. Seeing as how there's no sound or response when i hit the multifunction switch I'll assume no power is getting there. Thats my target.
Quick Reply: Turn Signals, Hazards, Brake Lights not working
