Where is my voltage regulator located???
Old 02-25-2010, 12:11 AM
tinkerinman's Avatar
tinkerinman
tinkerinman is offline
Question Where is my voltage regulator located???
Is it in-line or is it in the alternator itself????
Old 02-25-2010, 12:20 AM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
On the back of the alternator.
Old 02-25-2010, 12:21 AM
tinkerinman
so i can replace it w/o having to replace the alt???
Old 02-25-2010, 12:43 AM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
i thought it was in the pcm?
Old 02-25-2010, 12:45 AM
yakkier's Avatar
yakkier
yakkier is offline
i thought it was the PCM
Old 02-25-2010, 01:02 AM
tinkerinman
so.... must i buy a new PCM or can i replace just the voltage regulator????
Old 02-25-2010, 04:28 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Read this thread
https://dodgeforum.com/forum/2nd-gen...g-problem.html
Old 02-25-2010, 05:51 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Read that thread Sheriff posted for you for reference and trouble shooting, But too answer your question, no, you cannot just replace the VR in the PCM.
Old 10-22-2018, 05:41 PM
Moparncuminsman's Avatar
Moparncuminsman
Moparncuminsman is offline
Default Voltage regulator
Yes you can bypass the pcm I've do it on several dodges diesel and gas burners if it does in fact test to be bad you can purchase a external regulator a three wire one for older Chrysler or Jeep or whatever and mount it somewhere on the fire wall . Keep in mind to he alternator works off of the ground not positive wire another words the regulator when it sense the need to start charging connects the ground this wire going to the alternator is also called the Exciter wire .
Old 10-22-2018, 07:52 PM
Eight year old thread??
Quick Reply: Where is my voltage regulator located???
