Engine Serial lookup
Old 03-24-2010, 11:27 AM
nightsbird's Avatar
nightsbird
nightsbird is offline
Default Engine Serial lookup
I was wondering if its possible to tell what vehicle and engine came out of based on the blocks serial number
the number is
8M 239 0408 2665
which using google i found
yr made 98, 239 ci, april 8th, and 2665 the serial
however i cant find where to see what that engine was in e.g. specific year, make and model that it was placed in
Old 03-24-2010, 01:31 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
I have never heard of someone doing this before, although that is pretty cool.
YOu trying to get your 3.9 V6 "Numbers Matching?"
Old 03-25-2010, 07:20 AM
nightsbird's Avatar
nightsbird
Actually I bought the truck used with a bad motor. Went to a salvage yard and purchased a motor that supposedly was out of an 01 Ram 1500 with only 72k miles. However none of the parts oil pan, pump, pickup screen seem to match an 01. This in itself wouldnt be a big deal but that engine was bad too. I am trying to prove breach of contract for lying on the age and mileage to get my refund since normally salvage yards do not give refunds.
Would anyone know if a block made in 98 as in the one above would have been used in 01 or if dodge generally makes only enough for the production year
Old 03-25-2010, 11:52 AM
MrRuckuss's Avatar
MrRuckuss
MrRuckuss is offline
there was a book i bought to help me build my bbc, in it told you how to look up all that info, go to a bookstore and look for a book on rebuilding or blueprinting a dodge engine that should give you what you need. then again call the dealership they should be able to help you with that.
Old 03-25-2010, 12:01 PM
yakkier's Avatar
yakkier
yakkier is offline
Dealership as suggested above.
Old 03-25-2010, 01:53 PM
nightsbird's Avatar
nightsbird
The dealer is only able to look up info with the last 8 of the vin. I called chrysler corporate and the Warren truck assembly plant both are looking into the matter. to see if those records are kept.
Thanks MrRuckuss Ill check it out maybe it can help.
Old 03-25-2010, 02:23 PM
yakkier's Avatar
yakkier
yakkier is offline
Man they are bound to have some kind of record considering they store all of our vin numbers all the way back to the mid to early 80's so i dont see why they wouldnt have the information on file. if anything they could look up the engine and find the vin number then look up truck from the vin number atleast.
Old 10-18-2017, 09:01 AM
MrAllen87's Avatar
MrAllen87
MrAllen87 is offline
Default I have a 4.7 magnum. Needing help
i have a 4.7 engine in my 02 Dakota, I am trying to determine the year of the motor to obtain the correct head sprocket for the passenger side. When I bought the truck I was told the engine was replaced but not by what year. It is not an 02 I know for sure the head sprocket is way smaller and wider then the one on it currently. Where can I find the block serial number and how can I cross reference it to find a year?
Old 10-18-2017, 10:28 AM
HeyYou is online now
Received 3,174 Likes on 2,927 Posts
Should be a date code cast into the block somewhere......
Old 10-18-2017, 10:51 AM
MrAllen87's Avatar
MrAllen87
I have found a 4 digit code under the front right side of the motor. How does it read and how do I read it or where can I look it up?
Quick Reply: Engine Serial lookup
