Brake fluid leak...What the heck is this? HELP???
The other day i was checking my oil and noticed some wetness leaking down the inner wheel well. So i put my finger in it and it was brake fluid. I traced the leak to what looks like an aluminum distibution block with brake lines running into it. And an electrical connector plugged into one side. Its got a ''NUT'' or somthing on the bottom and the middle of that nut is leaking.. I cant quite look at the bottom but it feels like theres somthing in the middle of that nut? Maybe an alan screw or somthing? Im pretty sure its just leaking from the very middle of that nut like thing....
Whats going on here guys? I had to stuff some paper towels under it the other day so i could drive my truck to town. (i didnt want brake fluid dripping on anything again) Its located right behind the battery and fuse/relay box on top of the drivers side wheel well..
Any help?
Any help?
Everything is as dry as can be. Every single brake line connection and everything. I folded some paper towles up and put them under that purge nut when i went to the store and its comming right from the middle of that nut. Any ideas? Im lost. Is there suposed to be a screw or somthing in the middle of that nut? I looked with a mirror a second ago and its a solid nut with spout like thing in the middle that has a hole in the middle of the ''spout''.
