belt and pully routing
Old 05-17-2010, 08:11 PM
mark2424's Avatar
mark2424
mark2424 is offline
Default belt and pully routing
i havea1985 dodge ram van i changed the timing chain and cant remember how it goes back together [power stering alt idlers ect] is the someware i can find pics
thanks
Old 05-17-2010, 08:12 PM
mark2424's Avatar
mark2424
mark2424 is offline
the motor is a 318
Old 05-17-2010, 08:21 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Read this thread, you should get some clues in it:
https://dodgeforum.com/forum/dodge-r...-assembly.html
Old 05-17-2010, 09:21 PM
mark2424's Avatar
mark2424
mark2424 is offline
that helped with the left side now for the alt and ac tensioner and bracket
thanks alot
Old 05-18-2010, 12:48 AM
alloro's Avatar
alloro
alloro is offline
I posted a picture in that thread showing the front of the motor. You can see the alternator bracket(s) on the left. Did you view both pages of the thread?
Old 02-25-2012, 01:17 PM
captain_wow's Avatar
captain_wow
captain_wow is offline
hi i have a question about accessory belt route so thought it best to post in here.
my 318 has aircon but its not working right now so ive removed it and bought the shorter serp belt as listed in rock auto. however when i re route the belt to miss out the ac compressor-(no longer there) the belt seems to pass itself way too close above the fan pully.. in fact its touching itself..(ooh err) is there a way of lowering or highering one of the pullys to give it some clearance? anyone else done this? otherwise i guess ill have to put the compressor back in place..boo.
Old 02-25-2012, 01:32 PM
alloro's Avatar
alloro
alloro is offline
You're supposed to add an idler (A/C bypass) pulley when the compressor is removed.
Old 02-26-2012, 08:21 AM
captain_wow
ah i see..any idea where id get one of those?
i guess that would bolt onto the bracket where the ac used to be?
the routing diagram on the hood doesent mention it. although it is definitely not drawn to scale.
Old 04-05-2015, 11:03 PM
d2fel's Avatar
d2fel
d2fel is offline
Location: http://www.facebook.com/home.php?#!/profile.php?id=100000188795062
Any idea where to purchase such an item, I will continue searching, but any vectoring would be great... my disabled ac is squealing like crazy so its replace the ac or get the bypass pulley...I'm cheap and don't need ac but don't much like the noise, nor do i want it to seize.
cheers
Old 04-06-2015, 04:38 PM
alloro's Avatar
alloro
alloro is offline
Here is an example of the bypass pulley for dodge motors. I don't know your model specifics so you'll have to look up your exact fit one.
http://www.summitracing.com/parts/rn...iew/make/dodge
Quick Reply: belt and pully routing
