Best Gear Ratio?
Old 06-18-2012, 10:27 AM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
Default Best Gear Ratio?
I don't know much about gear ratios so I need some help. I'm pretty sure I've got stock 3.55's and I was looking at 4.11's and 4.56's. I only have 2WD so I don't plan on getting bigger tires either. I'd like to still be able to tow things obviously but I want more performance. I know I'm probably asking very generic questions, but I'm so lost haha
Old 06-18-2012, 10:31 AM
Wombat Ranger's Avatar
Wombat Ranger
Wombat Ranger is offline
If you are gonna stick with stock tires, 4.10's will wake the truck up nicely and still keep highway driveability.
Old 06-18-2012, 12:02 PM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
4.10's it is then! Thank you
Old 06-18-2012, 12:05 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
+1 on 4.10's
Old 06-18-2012, 01:28 PM
98Ramboy's Avatar
98Ramboy
98Ramboy is offline
Now, I have a limited slip rear end, does that affect anything?
Old 06-18-2012, 01:52 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
I have a set of used 3.92 here $100, lsd makes no diff for gears. Inspect those lsd clutch disc's.
Old 07-08-2012, 09:50 PM
WAltom's Avatar
WAltom
WAltom is offline
Not trying to hijack your thread......but,
I added some 305 70 16's to my 2001 Ram 1500, it's has 355's with auto......it won't pull the hat off your head. I had 265's on it and it wasn't any better. The tag on the door says the truck came with 225's but the unused spare is a 245. I got a good deal on some used 305's that's the only reason I put them on, was going on a camping trip pulling my 27ft fifth wheel. What ratio do I need to go with for 245's or 265's for pulling? I don't drive the truck too much cause it getting terrible gas mileage anyway but when I do have to drive it to work it about 35 miles one way.....the rest of the time it's only used for pulling. It got 13-14 with the 265's...not sure if it's changed much with the 305's.
Old 07-08-2012, 10:45 PM
lastrights's Avatar
lastrights
lastrights is offline
I say 4.56 even people who own dodge Dakota rt they run 28 I.ch tires get them . It will be a beast ! !
Old 07-08-2012, 11:01 PM
Wombat Ranger
Agreed, 4.56's for 33's and towing duties. Then when you want 35's later on you wont have to worry about re-gearing then either.
Old 07-08-2012, 11:38 PM
Received 3,165 Likes on 2,919 Posts
But towing, even with the 4.56 gears, and 35 inch tires, will be rough. If you PLAN on 35's, go to 4.88 gears. ESPECIALLY if you plan to tow that heavy trailer.
Quick Reply: Best Gear Ratio?
