Odometer not working....JUST the Odometer..Solution??
Old 04-10-2013, 05:49 PM
mcclymont's Avatar
mcclymont
mcclymont is offline
Question Odometer not working....JUST the Odometer..Solution??
Hey all.....
Long time listener...first time caller....lol
Anywayy.....
Heres the deal....2005 RAM 1500 HEMI Sport....few months ago, the odometer(digital screen) went out...then a day or so later came back on....then a few times while driving, the odometer lights (just the odo lights/display) started dimming....then got brighter (regular brightness).
Was fine for a week or so....then it went out again...then came back on a day later while still accumulating proper milage....
Now its been out for about a week..
All else in the truck (lights, door locks, etc) and rest of the gauge cluster work....just the odometer screen (that shows odo, "lamp out", etc...) wont light up / display anymore.
Speedo is fine, Tach is fine...all other lights, etc.
Anyone else experienced this phenomenon???
All fuses seem OK, is there a common problem with this or is there some area (wiring, connectors, plugs, etc) that I should be looking at / for??
Is the whole gauge cluster shot? Orrrrrr....can just the odometer screen/module/doo-hicky be replaced???
I can get a used cluster....but of course, concerned about the milage on it....
Any help would be greatly appreciated
Old 04-11-2013, 01:39 PM
kenneymc's Avatar
kenneymc
kenneymc is offline
Sounds like a loose wire or bad solder joint. Never had a cluster out, but I would look in to pulling it and giving a good visual, checking connections, pin seating, etc.
Old 08-19-2013, 10:05 PM
rickrrs's Avatar
rickrrs
rickrrs is offline
Default rickrrs
I have a 2004 ram 1500 5.7 engine and the exact thing is wrong with my odometer screen also. EVERYTHING else except what is inside that odometer window works perfectly. I have tested all fuses. I have removed cluster and tested connector pins and looked for bad solder joints. found nothing. Put all back together, still the same.
Have you corrected yours yet??? Would you share what you have done and have found???
Thanks
Old 04-18-2014, 12:35 PM
whisky402's Avatar
whisky402
whisky402 is offline
Yeah I have the same thing going on . 05 ram 1500 4x4 , light is bright then dim then out then bright and so on. Don't have a clue why but it just started a few weeks ago. If anyone has fixed this before please post how you fixed it. thanks...
Old 04-24-2014, 05:10 PM
RonaldWright's Avatar
RonaldWright
RonaldWright is offline
Yes please some one help us, I have a 02 quad 4.7 and this has been braking my head none of the lights on the odometer side works at all but chimes when I have almost no washer fluid I've taking mine apart and had a buddy that is a computer guy test every square inch of the board and everything tested fine he said..it's been like this sense I bought the truck and only came on once before I could pull any codes.... Checked and fixed all wires in doors just to be on safe side and didn't help..... If I replace cluster and that helps ill post it when I get it in but still trying to figure this out
Old 07-17-2015, 07:39 PM
brad m's Avatar
brad m
brad m is offline
Did anyone every find out what was the problem. I'm having the same issue now.
Old 11-08-2015, 08:30 PM
mcclymont's Avatar
mcclymont
Nope, never fixed the problem....
Now, it hasn't come on in about 3 months.....
id REALLY like to have the solution...
Old 12-20-2015, 02:41 PM
8ezmusl's Avatar
8ezmusl
8ezmusl is offline
Same issue on my 05 5.9 3500 please anyone find a fix yet?
Old 12-20-2015, 02:49 PM
8ezmusl's Avatar
8ezmusl
8ezmusl is offline
Did you ever find solution, I have same issue.
Old 04-09-2017, 02:35 AM
calebnolta's Avatar
calebnolta
calebnolta is offline
Has anyone figured this out?
Quick Reply: Odometer not working....JUST the Odometer..Solution??
