[5th Gen : 08+]: How to Close 3rd Row Windows
I am driving a 2011 Dodge Grand Caravan. One of the kids opened one of the 3rd row side windows, but now it seems impossible to close it. Any tips? They are the hinged windows. I can't even tell if the hinge needs to turn up or down to bring in the window - it seems totally stuck. It is almost enough to make me think they are power windows, but I've never seen any button to open or close them.
Appreciate any help - want to get them closed before it rains!
No owners manual? Download it from the Dodge website. It will show you the location of the buttons - probably on the driver's door. To close them manually on earlier models you just bush the elbow in the linkage off center from the inside then push the window closed from the outside.
If they are power windows the controls would be located in the driver's door armrest behind the power lock switch. If only one of the windows is open then you most likely have manual windows as the power windows open both sides at the same time and as far as I know there is no way to open one window independently.
I believe you have to push up on the linkage that holds the window open in order to close it. When all else fails check the manual as Cougar41 said.
I guess I reply here. I own a 2016 Dodge Grand Caravan and I couldn't close my rear windows either. The button is on the DRIVERS side door panel. Welllll... I forgot to PULL UP on the switch to reverse the "OPEN" which I accidently "pushed down" Didn't even think to pull up to close, since I pull UP to open my other windows.
The other frustrating 'feature' of these rear 'pop-out' windows (on my 2010 Grand Caravan) is that you have to remember that you opened them, in order to remember to close them. I've left mine open (accidentally) on several occasions and got rainwater in the the back area. There most certainly SHOULD be at the very least a light on the dash to indicate that the windows are open ...and ideally, a feature where the windows close automatically when the ignition switch is turned off. It would be REALLY great if someone developed a 'hack' for an auto-closing feature, or a warning light. I issue that challenge!!!
