2011 RAM 1500 DTC P0481 cooling circuit 2
I have been getting this code for awhile. At first I would clear it and it didn't back for awhile but not after I clear it it comes back immediately.
The condenser fan comes on high at startup for a few seconds then shuts off. When I check the connector I have 14 volts to both the low and high speed leads. When the fan turns off only the low speed side has 14 volts but the fan does not operate. Should the low speed be working or does there need to be some voltage on the high speed to run the fan on low?
I have been reading about the TIPM in these vehicles going bad and I was wondering how I can test it? I don't want to spend hundreds of dollars on a TIPM if that is not the issue. I have a service manual but I can't find anything about testing the TIPM.
From the diagrams it looks like there is another relay for the fan built into the TIPM and can't be serviced.
Thanks.
Thanks.
Thanks.
Thanks.
Last time I was there I asked them to flash EVIC to add the integrated brake controller I installed. They charged me $140 for less than 15 minutes of work. Total BS.
I'd recommend establishing a dealer appointment and once done so please DM me your VIN, servicing dealer and service advisor. If you need assistance establishing an appointment, please DM me. - Kevin T, Social Connect Team
From the VIN, it's showing a basic high/low system, LOW sourced from TIPM and HIGH from a relay mounted to the fan shroud. However, I've seen MANY trucks be off a year in the service info. For instance a 2011 has a 2012 wiring or a 2012 has a 2013 wiring or vice-versa.
Fan should be a 3 wire DG/DB, DB/DG, Black.
