P0139 Questions
Old 02-03-2017, 08:41 PM
dakoton's Avatar
dakoton
dakoton is offline
Default P0139 Questions
Hi guys, at the beginning of the week I got the check engine light, I went to the near autozone and got code P0139, the guy at autozone didnt want to reset the code with the tool so later in my home I disconnected the battery to reset it, the light came on today again, went to another autozone and got the same code, so looks like is not going away,
so a couple of questions:
what do you suggest? immediately replacement of the oxygen sensor?
if yes:
should I got the OEM?, the autozone version? or the cheapest ones that rockauto.com sells?
and lastly where the sensor is located, as far as I know the truck has 4 O2 sensors, 2 kinds of them according to the location,
thanks in advance,
Regards
Old 02-03-2017, 11:11 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Get NTK O2 sensors. The last one I did the upstreams on, I went through the wheel wells. If they're original, get ready to curse !
I think 3 of them are the same part number and the left upstream I think?...is the oddball one, so the pigtail can be routed away from the exhaust.
Old 02-05-2017, 05:04 PM
dakoton's Avatar
dakoton
dakoton is offline
I took a look on the truck here is a picture of the driver side:
the passenger side:
a closer look to the one that is on the upper:
if Am I right the one that I need to replace is the one on the red arrow, looks easy compared to the others one,
Am I right?
Old 02-15-2017, 09:29 AM
WvChamp's Avatar
WvChamp
WvChamp is offline
P0139 refers to a Bank 1 Sensor 2 Slow/Nonfunctioning (Drivers side rear O2sensor).
NTK Oxygen Sensor
Part No. 23158
Old 06-25-2019, 12:37 PM
cbea1124's Avatar
cbea1124
cbea1124 is offline
What part number for bank 1 sensor 1 since it is the oddball sensor...?
up 1/1 (part ???) up 2/1 (part NTK 21358)
dwn 1/2 (part NTK 21358) dwn 2/2 (part NTK 21358)
