Transmission interchange
Old 04-07-2017, 08:05 PM
Nicki Lynn Johnson's Avatar
Nicki Lynn Johnson
Nicki Lynn Johnson is offline
Default Transmission interchange
Will a 99 dodge ram 1500 4x4 transmission interchange.with with a 97 dodge ram 4x4 transmission?
Old 04-08-2017, 09:19 AM
jkeaton is offline
Moved to the correct section.
Old 04-08-2017, 07:22 PM
97ramrod1500's Avatar
97ramrod1500
97ramrod1500 is offline
Yes, direct swap.
Old 04-09-2017, 09:25 PM
J415's Avatar
J415
J415 is offline
Not really. The valve body solenoid are different on both.
Old 04-10-2017, 06:52 AM
97ramrod1500
Solenoids, and sensors inside the trans are the same from 96-99. The only difference from 96-97 to 98-99 is in 98they switched over to the plastic encased filter. Ive rebuilt the valve bodies side by side and they are identical. I've swapped the transmissions throughout those years and no issues. This applies to 4wd only because the 96-97 2wd transmissions have the speedometer output in the tailhousing.
Old 04-20-2017, 03:50 PM
prez-reaper13's Avatar
prez-reaper13
prez-reaper13 is offline
so will a trans from 98 1500 5.2 4x4 be a direct no mod swap into a 97 1500 5.9 4x4
Old 04-20-2017, 03:52 PM
CJSuhr's Avatar
CJSuhr
CJSuhr is offline
Yes. Should swap right over.
Old 04-20-2017, 04:19 PM
prez-reaper13
Ok I thought I saw something about the torque converter or flex plates being different
Old 04-20-2017, 08:37 PM
Those changes occurred from 95 to 96. Should be a direct swap.
Old 04-20-2017, 09:47 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Between the 5.2 and 5.9?
I thought its internal vs external balancing.
Quick Reply: Transmission interchange
