Truck died, wont run, please advice
Ok guys. Im in need of some advice/direction. Im mechanically inclined and im sure i can fix any mechanical issues that need to be done.
That being said...
2006 dodge ram 5.7 hemi crew 4by4 sport. Driving on highway at 100kph. Engine running one second, dead the next. No loud noise, no excitement. Just on, then not. Engine turns over. Fires the odd time but never more then a single attempt. Wont run. Turns over fast enough. (Battery and starter only a few months old) NO CODES. fuel pump sounds fine. Plugs look good. Its had regular maintenance
Taken care of, but works hard when in use. It has 199,643 km.
I know what i think is likely wrong but i am looking for more opinions. What should i look into doing next?
That being said...
So. Still wont start. I have fuel and fuel pressure. I have spark. I have 130plus compression in 1-8 so the valevs are opening and closing. I changed the crank sensor. Still no codes. Something electronic must be messing with timing??? I am wondering how to test the computer? What should i be testing next? Or is it at the point of going to dealership???
