Surging idle/stalling
I have a 1998 dodge ram 1500 5.9L v8 -172,182 miles on it..
When I crank over the truck it will sit idle for roughly 2 minutes before it starts to surge, it's almost like a heartbeat and only happens after the engine has warmed up. After about 15 minutes it will stall. When I'm driving it and come up to a stop sign or stop light it will start to surge immediately and sometimes drop rpms until it stalls as well. Took it to run codes and nothing. No check engine light as well. Not sure what the issue can be? I NEED HELP, please.
What I've replaced and/or cleaned/fixed:
- Starter (locked up, doubt its related but thought I'd list it)
- iac valve (replaced)
- throttle body (removed and cleaned as best i could, about 95% of the gunk came off)
- coolant temperature sensor (replaced)
- spark plugs and wires (replaced)
Any suggestions would be amazing, thank you all..
So you were right, i unplugged the upstream o2 sensor and ran the truck for about 5 minutes.. No surging. This is looking to be my problem. THANK YOU, heyyou.
Only now I'm having an issue with the seatbelts.. Last night I noticed both retractors were clicking repeatedly and very fast, and the seatbelts are locked and will not pull out. This morning the clicking was no longer there. After work I had to jump the truck because the battery was drained (probably because it was clicking all night long) while it was running it wasn't there and the seatbelts were free to move. Shut the engine off and now its back. Not even sure of where to look for this issue. Any more suggestions would be appreciated deeply. Thanks.
I found the sctm, everything seems fine.. It was mounted in the way it should have been and all the wires leading to it seem to be connected correctly. Basically what I'm trying to say is it looked untouched, the zip ties put in place to prevent loosening connections were even still there.
Is it possible it could just be failing? It is seriously draining the battery and i can't keep jumping this truck for fear of destroying the battery completely. But i also need my seatbelts to drive, my job depends on a clean record and i don't want piled up seatbelt tickets.. Is there some sort of bypass i can do to release the seatbelts without it affecting safety and without the stress on my battery?
Control module part number is 56043003AD. Seems maybe it is still available new in a couple places..... Think I would call before ordering though. Other option would be to check car-part.com, they have a locator service. Should be able to get a used one relatively easily. Granted, it isn't going to happen as quick as you would like......
