1986 D250 Custom - No Turn Signals, Radio, or Windshield Wipers
Old 04-23-2017, 12:41 AM
matador's Avatar
matador
matador is offline
Default 1986 D250 Custom - No Turn Signals, Radio, or Windshield Wipers
I own a 1986 D250 (It has a 360 and is the base model- really base). I had a battery drain issue last fall, so I parked it over the winter and started working in it this week. I got it running fine- replaced the ICM and the Voltage Regulator. However, I now have a new problem. All of my lights and accessories work, except for the turn signals, radio, and the windshield wiper/washer. Any ideas?
Old 04-24-2017, 08:26 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
I'm assuming that you've checked the fuses and they're intact? It's unlikely that one of them would have blown just from swapping the parts, but anything's possible if you didn't disconnect the battery when you swapped the ICM and VR. If you still have the old parts, I'd say plug them back in and see if you've still got this same problem. If so, you're chasing wiring (probably grounds, or potentially a broken wire coming from one of the harnesses). If it goes away, you may have a defective part (uncommon, but not unheard of)
But, my money's on either a fuse of a cracked wire, personally. Good luck!
$.02
Old 04-24-2017, 10:35 PM
matador's Avatar
matador
matador is offline
A blown fuse was my first thought. I pulled them and swapped them for the ones in my other truck- the other truck worked fine, but these still didn't. So, I switched them back. I'll see if I have the old parts still. My guess would be on a split wire or something, but I just don't know where those three things would share a wire
Old 04-25-2017, 11:42 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
Without a wiring diagram in front of me I'm not sure either. My guess would be a common ground or common power supply wire coming off the harness
Old 04-25-2017, 10:48 PM
matador's Avatar
matador
matador is offline
I have a Haynes manual, so I can pull that up. I never thought to check on ground wires, though. Hopefully that's what it is
Old 04-28-2017, 07:40 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
Just checking in to see if you've had any luck?
Old 04-30-2017, 01:43 AM
matador's Avatar
matador
matador is offline
Waiting for a day when it's not pouring rain outside to look at her. It's way too wet here this spring
Old 05-01-2017, 10:49 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
Yeah, that's a good reason to wait. Nothing like a cold pouring rain to make working on your truck a miserable experience. I had to swap out an in-tank fuel pump on an '87 Nissan pickup years ago, flat on my back, outside, in a March rain storm. Never been so cold in my life.
