Best way to remove surface rust?
Im planning on painting my front suspension components, but they all have pretty heavy surface rust. Im painting my axle, differential, coil springs, shocks, and radius arms. What the best way to get that rust off? I was thinking CLR but ive never used that on a vehicle. Also, can i use rattle can bed liner on it? I want it to be as rust resistant as possible.
+1 on blasting. You can take the parts you want cleaned to a machine shop - they have blasting/peening equipment that can make those parts look like new bare metal ready to be primed and painted. You can also ask around to see if you can find someone that has a good bead blasting cabinet to do the work for you, too.
Yea HF makes a both a cabinet and a pressure blaster. When i got my truck the front axle was rusted up also. I pressure blasted it to clean metal then painted it. Not sure how well the pressure blaster works from HF. It's small compared to the one i built.
http://www.harborfreight.com/40-lb-p...ter-68992.html
