03 Ram 4.7 5 speed no gears
Hey everyone I'm new here but not to turning wrenches. So my clutch went out two weeks ago. I pulled the tranny. Clutch was bad, slave cylinder piston also came out in two pieces. Short story I replaced the clutch, plate, slave cylinder, throw out bearing, pivot spring, and pivot ball stud. Put it back together drove it for a week then suddenly it won't go into any gear. If I pushed halfway on the clutch it would go in fine, but all the way down in gear the truck would try to crawl forward. I changed the master cylinder today have bled it numerous times and still will not go into any gear. Ideas?
Well i got everything pulled back out and clutch and pressure plate look brand new still. One thing though. When I replaced the slave cylinder it came apart. I know it went back together right with the exception of the plastic piece behind the Piston. Is it possible that it could be back wards and cause these issues?
