[5th Gen : 08+]: When to bleed ABS and When do I need special tool
2008 Dodge Grand Caravan SXT, 3.8L
Hi, everyone. Thanks to this forum and a couple sites like moparpartsoverstock (useful part diagrams) I know just enough to be dangerous. So far I've replaced my own EGR valve and other fairly easy repairs.
The secondary brake tube from the master cylinder just ruptured! I am hoping to clarify a couple questions.
1) When I replace it, will I need to bleed the ABS system, or just the base system?
2) Will I need that special tool to compress the pistons in the rear calipers, or can I just bleed them without all that?
3) I am certain if I should use DOT 4 or DOT 3
4) Thanks!
4) Thanks!
As long as the master cylinder did not run dry just bleed the base brakes like normal. A scan tool is used to cycle the solenoids in the H.C.U. to help purge the air. From my experience just bleeding the base brakes is good to go. No need to compress rear caliper pistons unless your doing a rear brake job.
