Abs and e brake lights on
Old 07-09-2017, 04:12 PM
Jon w's Avatar
Jon w
Jon w is offline
Default Abs and e brake lights on
Just switched out the rear differential in my 2001 Durango. After completion the abs light and e brake light are on. Was not on before switching out differential. Any suggestions to what the problem is would be greatly appreciated.
Old 07-10-2017, 08:06 AM
jkeaton is offline
Broke a wire, damaged a sensor, etc.
Old 07-14-2017, 12:44 AM
adukart's Avatar
adukart
adukart is offline
Usually if its a sensor you just get the abs light. When its both on these, in my personal experience, the abs module is shot. Try the speed senor out of you old differential and go from there.
Old 07-15-2017, 07:52 AM
Pspklutch's Avatar
Pspklutch
Pspklutch is offline
Right before I swapped the rear end on my 98, I topped the old one off with fluid. When I did, metal shavings coated the sensor and I got no speedo plus the ABS and Brake light. Just some input, don't know if it helps of not.
Old 07-17-2017, 06:42 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
the speed sensor on the output shaft of the transmission works in conjunction with the speed sensor on the rear differential housing, if either one goes bad and stops reading correctly the abs and brake lights. IIRc one controls the speedo in first gear(or up to a certain speed i dont recall which right now) and the other takes over after that.
Old 07-22-2017, 11:34 AM
Compactc9's Avatar
Compactc9
Compactc9 is offline
Been there and doing this one on my truck, the ABS/brake light thing that is. I had to replace the ABS module as well as the master cylinder. Who I replaced the cylinder, the new-found pressure showed me I have some very rotten brake hoses, which I am replacing tonight after work. But I agree on the module, if its just a sensor, usually just the ABS light comes on, for my situation I did have to replace the module. Also, a word of extreme caution when replacing the speed sensor on the rear end, make sure you clean the area well before removing the old one, I think something fell in when I did mine, and then trashed the bearings in the rear end, causing Dad and I to spend several weekends rebuilding it with new bearings.
