3.7to4.7swap
Old 07-21-2017, 10:32 AM
jaymiez1's Avatar
jaymiez1
jaymiez1 is offline
Default 3.7to4.7swap
I have a 2008 Dakota with a3.7 and want to swap it out to a 4.7. I work at a large auto wreckers so I have access to almost every dodge engine made. What engine is my best option for this swap keeping in mind I'd like to install a turbo eventually!!
Old 07-21-2017, 11:55 AM
jkeaton is offline
Confused by your post. You want to swap your 3.7 for a 4.7 but then ask what is the best engine for this swap?
Old 07-22-2017, 04:34 PM
jaymiez1's Avatar
jaymiez1
jaymiez1 is offline
Default What year of 4.7
obviously you not the guy I was asking cuz I wanna know which year ,magnum or not you know what is the best 4.7 to install
Old 07-22-2017, 04:42 PM
jaymiez1's Avatar
jaymiez1
jaymiez1 is offline
Default Meny different 4.7
we have over 20 different 4.7 and I doubt there all the same so I doubt that my post is the only thing your confused by !!
Old 07-22-2017, 05:27 PM
jkeaton is offline
Ok then. Good luck.
Old 07-23-2017, 12:14 PM
dodgeman1977's Avatar
dodgeman1977
dodgeman1977 is offline
I have a 2005 4.7 non HO version, and its a pretty solid set up. It has more than enough power for what I do, but that depends on what you do with your truck.
I haven't done it myself, but I hear superchips is a good thing to do and may be better off than adding a turbo, you could look into that.
Old 07-23-2017, 01:56 PM
jaymiez1's Avatar
jaymiez1
jaymiez1 is offline
Default What engine
I have a 2008 Dakota with a 3.7 what engine woul be a good swap to obtain about 325-350 rear wheel hp?
Old 07-23-2017, 05:38 PM
Received 3,164 Likes on 2,918 Posts
5.7 Hemi. That's the only way you are going to get those numbers. Probably need a shoehorn and sledgehammer to get it to fit though.....
Old 07-24-2017, 01:07 PM
jaymiez1's Avatar
jaymiez1
jaymiez1 is offline
Default 2004 4.7 magnum
Any thoughts on a 2004 4.7 magnum from a full size Dodge Ram 1500 ? Good , bad ,worth a rebuild ,etc
Old 07-24-2017, 07:46 PM
Vladek's Avatar
Vladek
Vladek is offline
4.7 is a 4.7. besides the H.O. (forged parts). the motor is the same. you have to pay attention to the year of the motor. the tone rings change in 2009 i think. as for getting the that kind of power to the wheel. you might as well go for the hemi swap. it can and has been done before. i'm in the process myself. the hemi has more aftermarket support than the 4.7 also.
