2013 Ram 3.21 to 3.92 w/ LSD?
Found a wrecked 2013 Ram 4x4 SLT 5.7 4x4, but it has 3.21 gears. Researching what I need to do to swap in 3.92s....
Front: Since it is welded, is it easiest to just by a used complete carrier set from a 2013 or newer truck? Any issues with axle shafts?
Rear: If I go with the OEM LSD, I can just put in a new 3.92 ring and pinion and be done, but if I want a Detroit TruTrac I would have to get a 2011 or earlier rear axle? Or is there a way to change one axle shaft so I can use the DTT?
I had bad experiences with my 2004 OEM 3.92 LSD, are the newer ones better?
