Considering just throwing money at my existing truck
So I'm bummed that the 4wd Dakota I was so excited about didn't work out. I've been looking every day for a month, but I am pretty sure I have the cleanest Dakota left in my state, and I'm not super stoked about getting a different one with way more corrosion. I hate rust. The issue is mine is only 2wd.
I have a trip planned in about 5 weeks out west, and I'm planning on taking the Dakota offroading a bit up into the mountains; nothing crazy or rock crawling, just up mountain passes to go camping away from everything.
So I've been reading about offroading with 2wd, and it seems like the general consensus is a locking rear diff = you can go 95% of where 4wd trucks can go.
Has anyone swapped in a locker or LSD into the stock 8.25 rear end? I read the FAQ but didn't see any links to how difficult this would be to add. What were your experiences?
93 ragtop (04-28-2022)
If you are JUST replacing the carrier, and not re-gearing at the same time, the swap really isn't that bad. Grab a service manual, read thru the procedure a few times, gather the appropriate weapons, and go for it. Having a bud that had done it before help you out isn't a bad idea either.
I was quite impressed with how well my truck does in 2wd, with the posi. 4 wheel drive just means you can get further away from help before you get stuck. (so, bring the help with you.....)
Now, about your truck being the cleanest in Wisconsin, I know someone that would like to have a word with you lol. It's built to be a show truck, but it's not trailer queen either. But it does get garaged in the winter.
Anyways back to the topic at hand. Tires and driver common sense makes the most difference off road. And being your truck has an auto, if you haven't, add a cooler and delete the check valve and you should be golden.
Imo, it's not worth it to just swap the rear end for another one with brakes. Disc brakes make everything SO much better.
Forgive me if you've already mentioned this but how's the parking brake set up on your 9.25? Guessing you needed to swap the rear cables, but what kind did you use?
Sorry can't help there.. rust belt + no inspections = didn't hook it up. Thought I do know I've seen a thread or two out there that explains it. Iirc, it was a Durango with the 9.25 drums, and went to the disc. I'll try and find it when I get off work tonight, or tomorrow morning.
