Coolant leak by passenger door when AC/HEAT is ran
Hey Dodge people!
My 98 3.9L Dakota just started dumping coolant recently. It seems to really dump onto the ground (not inside the truck) when I run either the AC or Heat. I can't see where it is coming from, but its dripping down around the bellhousing and kind of behind the passenger tire -- under the front of the passenger, kind of where the side mirror is to give point of reference.
I was thinking maybe it has something to do with the heater core because it barely leaks if at all when I don't have the blower running, but as soon as I turn the blower on, it leaks like crazy! I thought heater cores only really leaked on floorboards inside the truck though?
Any ideas on what else may be leaking that is directly related to whether or not the AC/Heat is on? or maybe another question would be... could I rule anything out by that diagnosis -- ie. maybe freeze plugs/gaskets wouldn't leak any different whether or not AC/Heat is on??
Appreciate any help! It's hard to see back there in back of the engine compartment and there is crap in the way when trying to see from underneath. I was wearing a lot of coolant when I tried looking up from under there.... ugh.
I couldnt really tell by smell if what was leaking was antifreeze or water, because I added a bunch of water to the system just to get it back home -- might not be much coolant left in the engine - mostly water probably. Although I will say it started dripping cold, and after the truck had run for 20 minutes or so, it started dripping hot... which leads me to believe its probably leaking engine coolant and not condensation. Would condensation start dripping hot after the car has been running awhile?
I initially thought Heater core, since it was related to the heater or AC being run, but the inside of the cab in bone dry. No leaks inside the cab on the floorboard, etc.
