I have a 01 6cl.Dodge dakota quad cab. 2wd. It's 5 speed. It's been making this clicking noise, but when I touch the clutch a little, it stops Or when clurch is pushed in, it stops.. Also after driving awhile, it doesn't wanna go in gears. I gotta almost force stick to get in gears. Does anyone know the problem? I payed over 700 January for inspection, and I can't afford another garage bill. Thank you!
Got a p1682 code now. I had a new alt. Put in January this year. Still wondering about the clutch noise and it not wanting to go into gear after its hot an ran for awhile. Any suggestions?
Voltage regulator is in the PCM. If the alt. isn't charging, have it tested, if it works on the test bench, regulator is bad. You can go with an external regulator, or, change the PCM.
Hard shifting is a clutch problem. If it's making noise, it's time to change it.
