What transmission?
its either a 545rfe or a 45rfe. my 05 hemi had the 545 rfe
so count you shifts or check the id label on the left side of the trans just above the oil pan. easy way to tell if you have the 5 speed. 55pm if you hit your tow/haul button once it will shift out of 5th to 4th...if you hit the button a second time it will shift from 4th to 3rd.
they are the same trans, with the same case and internals but the 5 speed is programmed with a second overdrive gear. programming is the only difference.
5= forward gears
45 =torque capacity
r=rear wheel drive
fe= fully electronic
5= forward gears
45 =torque capacity
r=rear wheel drive
