Replace Transmission Case? '01 Dodge Dakota
Old 09-10-2017, 07:22 PM
perrylangill's Avatar
perrylangill
perrylangill is offline
Exclamation Replace Transmission Case? '01 Dodge Dakota
I noticed my transmission case is leaking transmission fluid and the case itself looks to be in terrible condition.
The truck shifts normally for the most part.
I saw a new aftermarket transmission case selling online for $60. Do I need any gaskets to go with it?
Can I simply replace the transmission case itself, and not the entire transmission?
Is this a repair something a novice could do from a Haynes book (ordered one today) or is this something I really need a mechanic for?
Old 09-10-2017, 07:29 PM
Skreelink's Avatar
Skreelink
Skreelink is offline
Replacing the case will essentially have you doing a transmission rebuild, since you have to pull it and EVERYTHING out of it. So if you feel confident doing a transmission rebuild, go ahead. If not, I would suggest taking it to a mechanic. Check around, some do not work on a vehicle if you bring your own parts and demand they order (and upcharge) for them. Be prepared to pay for a rebuild, as they'll likely suggest (and if it's apart anyway) is a good idea.
Old 09-10-2017, 07:49 PM
magnethead's Avatar
magnethead
magnethead is offline
i dont even know of an aftermarket 46RE case. Certainly not $60.
As mentioned, a rebuild would be suggestable at the same time unless the clutches and bands look new, which I doubt.
Figure $1500+
No it is not a shadetree job, requires several transmissions specific tools.
Old 09-11-2017, 05:34 PM
perrylangill
Unhappy thanks
Thanks for the response you two.
Its completely not what I wanted to hear but its reality, so thank you for that.
Old 09-11-2017, 06:43 PM
perrylangill
Question
I need to further ask, so its not recommended but it is possible to just replace the case and not do a transmission rebuild?
If so, what would a dollar figure approximation on the labor for just the case replacement and no rebuild be at a garage?
Old 09-11-2017, 06:57 PM
Skreelink's Avatar
Skreelink
That I cannot say, it'd likely be close to a rebuild in price, as a rebuild is mostly labor cost. Actual parts are only a couple hundred dollars, if that. Swapping a case would require removal of the transmission, and a complete dismantle of the transmission to transfer everything, putting it back in, then refill. They might also not warranty the work, unless they do a rebuild. You'd have to ask a local place and explain your situation. I would suggest AGAINST big name chains such as AAMCO (I've heard so many horror stories...)
Old 09-11-2017, 08:51 PM
magnethead's Avatar
magnethead
Agreed. The clutches and plates are around $400-550 depending on brand/source/dealer arrangement. Labor here in DFW Texas is around $95/hour on the low side (shop I used to be at was $110 per) and I believe the trans books around 7 hours to gut out and refill, with an hour in there for inspecting and pulling the burned parts and inserting the new ones, and washing out the case.
Again, i don't know of an aftermarket 46RE case. I have a feeling it is just a stock replacement casting by Trans Specialties or various other (typically Chinese) sand casting companies. You would not gain anything from it. If anything, could be weaker than a factory casting.
Old 09-23-2017, 10:20 PM
perrylangill
Default Transmission pan vs transmission case
Is there a difference between a transmission case and a transmission pan?
If the pan is different than the case, can one simply replace the pan without requiring a transmission rebuild? How expensive would the repair run in a garage for the leaky thing?
Old 09-24-2017, 09:45 AM
Pan bolts to the bottom of the case. (with lotsa bolts.....) Dropping it, and changing the gasket is easy, just messy...... Filter/gasket kit is cheap. Last I checked, a 'trans service' (replace the filter, and changing some fluid) is still under 100 bucks.....
