Frame rivets
Frame rivets
Is there a problem with cutting frame rivets and replacing them with bolts?
Specifically, the ones on the back of the frame. I took the bed off and I would like to clean the frame and paint it. Would be easier to wire brush, etc if the frame cross sections, spring hangers etc were not attached.
I'd use some good tight thread locker (the "Gotta Burn It Out!" kind, not the "Joe Armstrong and his Cheater Bar" kind) instead of a lock washer; but yes, the rivets were used for two reasons - 1)They're cheaper on an automated line, 2) They don't loosen up like nuts and bolts can.
If you know how to weld, you could always weld them together instead; that would also help make the frame a bit more rigid.
RwP
RwP
RwP
RwP
I went through and double checked all my nuts and bolts twice after driving the truck for a while. Oddly the only ones I recall being a little loose were the bed bolts which were original. Don't know how that happened but whatever.
Want to thank you both for your advise!! I thought bolts would be fine, and I figured locktite as well.
I plan to seperate everything and then wire brush best I can. I plan to coat with por-15 and then reassemble, coat with rustoleum paint.
Would have liked to have it sandblasted, but its just to big of a project to get into right now.
Been a few years since I used it, but (from memory) they say to coat if in a area with UV (sunlight) potential.
It may not be absolutely necessary, But I coat it with a spray can of rustoleum just to be safe. Its quick and cheap.
