Gear selector moves fine but the transmission will not engage.
I was doing a bit of searching and found the shift interlock to be a common problem. The gear switch lever moves from park to drive just fine but once I put it in drive, it's almost like she is stuck in park or neutral. It revs but doesn't move.
edit: 2005 Magnum R/T 5.7L
I also saw this and realized that I failed to mention that it will go into gear after I leave it off for about 20 minutes or so. Upon the initial star up it will shift into any gear just fine but, once I stop or take my foot off the accelerator pedal and them move back to it the gear is "gone." I just get the revving.
Dodge magnum
Did you ever get this problem fixed having the same issue and I’m trying to find out what the problem is
Gregg Wilson (12-10-2019)
What was your issue ? my car is doing the same thing
I was just wondering if you fixed it and what the problem was because my car just started doing it today plz lmk 3216169157
