I have a 2001 Ram 3500 with 2 H/L headlights, and was wondering if anyone has upgraded the headlights and foglights to LED??, and if so, which has been the prefered brand to go with?
Thanks...1958
If you are using the stock reflector type headlight housings you need to buy a LED headlamp that focusses the beam on the ground. The only ones I've found are the Phillips Lumileds, GTR Lighting has a set for $250, high and low beam bulbs. GTR Gen 3. It's what I'm using.
