High Shift Points, 1 and 2
Alright long story, trans shifted like crap and kept throwing all sorts of codes. I replaced all the sensors in the trans and it shifted better but was stuck in limp mode. Turns out my PCM wasn't sending any control signals and was bleeding my grounds. Ordered a new and programmed PCM and installed it two days ago. Codes are gone, limp mode is gone and it fixed a ton of other issues i had. Now the shift points seem extremely high. 1 and 2nd gears go up to 3k-3500 RPMS before it will shift. After that it is golden and shifts up and down fine. Ive tried adjusting the TV cable and it doesn't change much, any ideas? Does the TV cable get stuck sometimes? Also, when i try to pass, sometimes it kicks down and sometimes it won't.
Yes. I got some WD-40 and sprayed it pretty good and worked the cable back and forth. Man you have to have it set just about perfect. If it's off one tooth it won't be quite right. Mine still isn't perfect. It shifts at a good RPM now but now 3rd is really lazy and wants to kick down on me so I'll have to adjust it some more
