98 Ram 1500 4 Wheel drive rear brake issue
Old 09-20-2017, 06:51 PM
Pjgray's Avatar
Pjgray
Pjgray is offline
Default 98 Ram 1500 4 Wheel drive rear brake issue
The rear brakes on my 98 Ram 1500 4 wheel drive keeps self adjusting too tight. Any suggestions on what would be causing this to happen?
Old 09-20-2017, 07:12 PM
Shoes loose on the nails? Spring broke? Shoes worn to the rivets?
Old 09-20-2017, 07:32 PM
Pjgray's Avatar
Pjgray
Pjgray is offline
After a closer look the shoes are wearing uneven. The springs do look ok
Old 09-20-2017, 07:40 PM
Pjgray's Avatar
Pjgray
Pjgray is offline
Not sure if a picture would help
Old 09-21-2017, 09:38 AM
Are the shoes on backwards? The shoe with the shorter pad surface should be on the FRONT. (can't really tell which way is which in the pic.)
Old 09-21-2017, 11:06 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Adjuster looks too crusty for my taste. Try a new adjuster kit and even springs. Lube everything accordingly.
