Vin tag
Old 09-20-2017, 09:25 PM
97ramrod1500's Avatar
97ramrod1500
97ramrod1500 is offline
Default Vin tag
Is the vin tag in our trucks riveted to the dash top or the cab itself? I'm going to be doing an extensive swap between my trucks and while I have the dash out I'm going to install a new dash top from LMC. wondering if I'll have to swap the vin tag onto the new dash or not.
Old 09-21-2017, 08:16 AM
jsmith1969's Avatar
jsmith1969
jsmith1969 is offline
It's attached to the dash, only takes a couple minutes to switch it over though
Old 09-21-2017, 03:11 PM
Tboned's Avatar
Tboned
Tboned is offline
On dash and easy to swap.
Old 09-21-2017, 03:25 PM
97ramrod1500
did you just use regular rivets to re-attach the tag?
Old 09-21-2017, 03:34 PM
Tboned's Avatar
Tboned
Tboned is offline
Yes, reg rivets. I'd be tempted to pull the entire dash to replace top. really not that hard, and it installs better as a complete unit. Dash will tilt back but it's tight for me . Pulling column would make it much easier i think as it would rotate back further.
Old 09-22-2017, 05:34 AM
97ramrod1500
Yeah, I'll be pulling the complete dash out. I am taking the cab and body off my truck and putting it onto the diesel I just bought. I need the harness out of the diesel and will install that into my truck.
Old 09-22-2017, 05:35 AM
97ramrod1500
Yeah, I'll be pulling the complete dash out. I am taking the cab and body off my truck and putting it onto the diesel I just bought. I need the harness out of the diesel and will install that into my truck. Figured there won't be a much better time to put a new dash top on.
