headlight issue
Old 09-22-2017, 02:10 PM
Rebhays27's Avatar
Rebhays27
Rebhays27 is offline
Default headlight issue
any ideas as to how to repair or find why my headlight will not come on when starting my truck the bulb is good as it will come on if you bump the assembly. I have removed the headlight assembly and the light will be in tight when I start to replace it it stays on. all the wires and connections are tight. I don't want to spend the 30.00 tio replace the light if it's not bad, or is it?
Old 09-22-2017, 02:14 PM
Received 3,165 Likes on 2,919 Posts
Can you get at the connector with everything in place?
Old 09-22-2017, 02:38 PM
Rebhays27's Avatar
Rebhays27
no its completely contained behind the frame
Old 09-22-2017, 03:01 PM
well that adds interest to life...... If you can wiggle the connector, and the bulb comes to life.... that would tend to point to the connector as the issue. If shaking the housing makes the bulb come back on, I would wonder if the filament hasn't broken.....
Old 09-24-2017, 01:58 PM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
You could try swapping the bulbs from left to right to see if the issue follows the bulb or stays with the wiring. If it follows the bulb, there's a pretty good chance the bulb is the issue. If the issue goes away, the problem may still be with the bulb, but maybe gravity is working in your favor in the new orientation.
-Rod
Old 09-24-2017, 04:27 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
I see a lot of bad connectors on these. One terminal gets hot and your connection goes nuts. I would pull the headlamp out and look it over.
Old 09-24-2017, 08:24 PM
Rebhays27's Avatar
Rebhays27
Haven't thought of this I'll try it when I get a chance thanks
Old 09-24-2017, 08:26 PM
Rebhays27's Avatar
Rebhays27
-Rod
